Scaling 1794-IE8 with Emmerson's FC-375
aganid
Apr 2003
Bogor
Hy Guys,
I am doing scaling AB-Flex Analog Input 1794-IE8 with RsLogix-5000. I do scaling by 2 defferent method. The 1st-one I use direct Current source 4-20 mA, I get Integer 70 to 30840 for 4 to 20 mA. The second one I use the Emmerson's Field Comunicator-375 (FC)as current source. FC not direct inject to 1794-IE8 but via Rosemount Hart-TriLoop. I measure the 4 to 20 mA output by DVM is OK but I get the Integer value is between 732 to 32728. Please some body help me why I have 2 deferent Integer Range
I am trying to scale an analog input for 4-20ma. Rockwell's website says that 0-30840 are the proper numbers. But the unscaled input raw is...
1,890
Hi, I am using an Analog Input Module - 1794/IE8 My Analog Input Module is configured for 0-20mA Unscaled Max = 31208 Unscaled Min = 6241.6...
7,058
Hey guys, I'm reading in analog values from 1794-IE8 flex IO card to my PLC-5/40 using BTR instructions. Now, I'm doing my scaling in wonderware...
9,899
Just commissioned two new skids for a customer. Each has a 1794 chassis over Ethernet back to an L81. The second module of each chassis is a...
2,402
Hello. Wanted to ask you seasoned vets out there about a scaling issue I'm having. Controller migration. A 1771 IFE 0-5VDC analog signal...
2,534
