Scaling 4-20ma for mb read out - Step 7
Blue Fox
Feb 2013
Basildon
49
Hello all,
Think my brain has stopped working as I just keep going round in circles and just cant seem to figure out how to do this for some reason!! Basically I have a pressure transmitter reading from -1 to 1 bar giving a 4-20ma signal back to an AI card (Siemens S7 400). Basically I want to scale this to give an actual positive and negative mb reading so I can put it onto SCADA, but for I think my brain has already decided its having an Easter break as I just can't get my head round it. Any pointers would be good!
Thanks for any help.
Use FC105 (Scale) from the library and put in 1 and -1 in hi and lo input respectively. Or -1000..1000 to get mBar.
or am I getting your question wrong?
5069 IF8 with a 4-20ma 0-100psi, sealed fixed, no calibration, transducer attached. IF8 is scaled 4ma= 0 psi, 20ma=100psi. If over time the...
2,667
Hello, I have looked through the archives and haven't had any luck on the basics of scaling. I'm trying to refresh myself and what formulas I can...
2,741
Hey guys, Normally I have an add in instruction that does this for me but the version of RSLogix I have (borrowed laptop) doesn’t have AOI’s so I...
19
9,777
Hi, im using a wago 750-455 connected to s7-300 cpu I use fc105 but the scaling is not right, the value is 20% off. Almost like the fc thinks im...
4,379
Hello, I am seeing an issue with inaccurate tank level. It is an elliptical bottom tank with an Anderson Level sensor mounted on the bottom of...
20
7,564
