Schleicher Promodul
kootni
Nov 2018
England
69
Hi can anyone please help me understand how Promodul Unit works. This unit is found in a plastic winder machine. I am at loss as cant find any material on net.
Need to understand what those numbers mean including A1 and A2.
Pls see attached pictures
These are totally obsolete but at a guess A1 & A2 are the power terminals.
Wire numbers 774 & 775 appear to be ov & + supply
More help...
Hi Parkey
what make you think 774 & 775 are ov & +? i thought so too and i think you may be right. Just need to trace wire.
But any idea what "S" is on the unit?
I think the S numbers are supply to the I/O A1 & A2 Are the 24v supply to the unit. Noticed "S" on one module is connected to Wire 775 which is supply
"S" is common connect of two NO (normal open) contacts - two relays- next to the "S".
See drawings on the cover.
For example "S" between 22 and 23 is common for two relay outputs 22 and 23.
I have a customer that has a Schleicher ProdModul-F on a CNC woodworking machine. Somehow the G-code file got corrupted on the internal memory of...
5,122
Hi all Long time creeping on plctalk so hope someone can help me. I have been coming across a few Schleicher PLC UCS 50s as of late i i do not...
1,347
Are any one know how can I work with this plc
3,445
Hello, I have a schleicher program that i am upgrading to Siemens. Can anyone help me with the following instructions: HRA, LRA, LDA, LDW, AAW...
3,185
Hi Guys, I'm repairing a sanding machine that operates by a Schleicher PLC. I've looked for its programming software but i didn't find it :(...
13,516
