Schneider Electric PLC Programming
mjp123gp
Mar 2012
Savannah, GA
94
I need some help with a Schneider Electric TM221CE40R controller. A customer wants me to add a few level switches and do some basic programming but I'm not familiar with this controller at all.
The previous contractor retired and didn't leave any electrical drawings or PLC files with the plant so they're in a bit of a mess.
-With this controller, can the program be uploaded from the PLC to my laptop? -Are descriptions stored in the controller?
-What software is needed? From the little bit of research, it looks like EcoStruxure is the software but I'm not positive.
Mark
I have never used Schneider but there are a few things you need to know.
1. In general, the comments & symbols are not stored in the PLC by default so it is likely that if you upload the code into the IDE there will be no comments or symbols, many PLC's have the ability to store the symbols & comments but many programmers do not so you may need the original source files for the comments.
2. If it was a contractor it is also possible that they have password protected the code so you can only access it if you have the code, many do on the premise that it is their intellectual property, or they consider it bad practice to allow others modify the code as it might cause problems, if it was specifically written for your company & the company paid them to do it, not a standard build i.e. an OEM machine then it should be your property, however, this is a contentious issue, debated by many.
Some PLC's cannot re-constitute the code unless the source code has been downloaded to the PLC, the only thing you can do is give it a try & upload it if it will allow.
If it is possible to upload the code & it translates into ladder then you could add comments based on the drawings, however, it appears you do not have these either so a little difficult and not for a beginner.
I am using a M221 PLC (TM221CE24R) which provides me 1 Rs485 port, which I am already using to communicate with a sensor (Rs485/Modbus). My...
749
Hello, I am trying to detect when the PLC changes from STOP to START mode. This can be considered an edge case scenario, but I would to analyze...
1,567
Hi. I am, in fact, not an specialist in PLC's but, in my work we remotely access a gear 500 kilometers away and we have observed, after some...
2,531
Hi, Sir anybody know the link for the programming software Schneider electric LMC058. i NEED TO UPLOAD THE PROGRAM FROM LMC058 Motion...
3,274
Dear sir, I've Schneider electric Quantum series hotstandby plc 140cpu67160 and unitypro XL 2.3V and OS loader 2.31V.I've problem that when power...
6,878
