Schneider Somachine
CDale1989
Feb 2017
Newcastle
I am hoping to view the logic currently downloaded to a Schneider TM241 controller but don't have a copy of Somachine which i believe is the programming software.
I only need to get an idea of the current workings of the machine so editing the software will not be necessary
Does anyone know if there is a free downloadable software package i could use to do so?
I thought there would possibly be a free trail version of Somachine but apparently not according to Schneider
By default the source application is not sent to the controller so there is no guarantee you will be able to get application out of it.
https://www.schneider-electric.co.uk/en/faqs/FA238799/
It's going to be much easier asking the manufacturer for a backup
Thanks.
Even if i get the source code though i have no editing software to open it in. Do you know of a free software i can use to view it?
Hello dear experts, I incurred in an anomaly while working with HMISCU devices by Schneider. I downloaded the program and everything seems to...
450
Hi all, I've been trying to develop modbus rtu program between uv balasts and plc ı'have 6 slave balast.I am reading fault run voltages etc...
1,200
Dear All, I need to know if I have a pressure analog signal input(4-20mA) and need to get an output analog signal (0-10VDC) to a pump controlled...
1,886
Hi! Anyone know if it possible to use UserManagement with SoMachine web visualization? The library does exist and the tab to configure it also...
1,227
Hello! I am new at PLC programming. I am using TM221CE16R PLC with TM3AI8 analog input module and SoMachine Basic v1.6. I am trying to scale...
7,077
