Schneider Unity Pro DFB import Problem
attendre
Dec 2014
Egypt
I have a problem for importing DFB Blocks in a project of Unity Pro V3.0.
I have a compressed file containing the Database of DFB Blocks with a file named Library.DSC
I know that it is easy to import DFB Blocks library if I have file.XDB
So, my question is: Is there any method to Convert the file.DSC to file.XDB ?
Note: I use the tool of 'Types Library Update' in Unity Pro Software Package for importing and Updating the family library 'Libset' only (file is Family.DSC). But for Derived Function Blocks DFB, a message 'Invalid directory, only Family.DSC is Valid'
I didn't create the the .dsc file
I received the Compressed file containing the Database files and the .dsc file
And these files are tested in Other Plants.
Note: The Database files and 'library.dsc' file are created by The Company 'X' with its library Standard and I should use its Standard library and DFB's.
Look in the context in the help file under this displayed section. This will explain how to do this. I have not done this myself yet so cannot say with conviction to do this seeing you are running an old version and they had quite a few bugs back then
I did this in the Family.dsc file and I updated the Libset in Unity pro.
But when I chose Library.dsc file, I got message 'Invalid directory or file name.Only Family.dsc authorized'
Hi, I've exported a PL7 application to the .FEF file succesfully. Imported the .FEF file in my Unity Pro project, but two of the five sections in...
775
I want transfer my I/O data from schneider (Unity Pro) as a write data and RS Logix 5000 as a read data. I use Ethernet as an communication...
696
Is there a tool to convert a ControlExpert project (.sta, .ztx or .zef in v14.1 or v15) to be opened using Unity Pro (v11 or V10) ? Thanks,
2,248
Hi all, I'm sure this is a stupidly simple question, but I'm really struggling to find any EFB or similar to do this. I want to map a block of...
3,403
Hi All, Can anyone explain to me: 1) What are 'PLC initialisation values", 2) What are 'Local initialisation values', and 3) Why I am getting a...
7,692
