SE Modicon M221 SHORT Instruction
KristienP
Jan 2015
Nova Scotia
44
Hi All,
I'm looking for some insight into what the SHORT instruction does. The help file wasn't very useful, as I found the explanation to be confusing.
So far, I've only seen them at the beginning of a rung, and not all rungs have them, so I'm confused why some do and some don't. The logic appears to act the same with or without the SHORT instruction.
Pics attached of the Help File & a rung of code.
Thanks in advance!
It don't do nothing. It is same than line, but compiler wants to add it before paraller contacts.
Also line is not allowed on paraller with contact and lead to error. But you can use short to bypasss (shorting) contact on program if you make online edits.
Thank you, I'll continue with assuming I don't need it. It seems to be something from really old versions of the SE programming software.
I think that it comes from Schneider Twido series as M221 is sussersor for that. Twido series was new around 20 years ago.
Compiler adds short commands sometimes and if you upload from PLC there is sometimes extra short commands which wasn't on original code.
Short and open are allways true and allways false commands. This is from twidos manual and explains them much better.
Hello All, I am stumped on how to convert a %MW to a %MF using Machine Expert Basic and a Modicon M221. The help files show a word to a double...
145
Hey Programmers, Heres todays puzzle I was trying to solve... I have a Modbus TCP network with two Modicon M221 controllers live on my work bench...
487
Hey everyone! I have trouble making sense of the math conversion in this seconds tag of the Modicon M221 Real Time Clock. I thought I understood...
1,629
Hi all, i am trying to scale a 0 - 1000 analogue input to a -10000 to 10000 output with 0-500 been -10000 to 0 and 501-1000 to 0-1000 is there...
2,914
Hi all. I’m currently trying to combine 3 memory words in to a single display on a weintek hmi as I want to display running time. I have the...
1,851
