krakenfan69
I have a PLC5/80E that I want to poll a Modbus device into using a Digi1. I have setup the message as a multihop going to the IP adress of the Digi and then to a compactlogix backplane to the node address 5 (the end device is set to 5 as well).
Using MDbus I can poll through a 485 converter into my PC.
I can't for the life of me get the setup in the DIgi correct.
In the Digi I set it up with a Network Master DF1 Ehternet to Modbus RTU using Port 1 and the screw terminals. I connected 2/4 & 3/9 on the terminals. As far as I can tell looking at the lights the Digi isn't even passing the message to the serial port.
Any chance someone can shed some light on this for me?
Thanks,
****** Fan #69
Thanks,
****** Fan #69
