Selecting a Feedback Cable.
HoldenC
Sep 2012
Cumberland, KY
220
We had a servo motor feedback cable get damaged recently and we want to order a replacement.
The current cable is a custom made cable, and we wanted to change back to something easier to get.
Can someone help me verify the part number.
Motor - MPL-B420P-MJ72AA
Drive - 2097-V34PR6-LM (Kinetic 350)
Current Cable - BCI-PUR-HRU-UXFFMF-S-047-2509CBL
Replacement - 2090-CFBM7DDCEAFxx
This cable has a molded DB15 on the drive side.
I used their ProposalWorks software and that cable looks right to connect that drive to that motor. It's options indicate:
Feedback only
SIN/COS High-Resolution/Resolver Encoder
Drive-end D-Sub connector
Motor End SpeedTec DIN Connector
Continuous-Flex rating
The "xx" at the end is the length in meters.
Edited to add:
It would be a good idea to reach out to your distributor to verify as well...
Hi, I'm working on Mitsubishi MR-J5-70A amplifier, and need some advice on selecting fuse size. Main power is 1ph 240VAC, and in the manual, it...
76
I am working on trying to create a an HMI program where the user can select a value from 1-25 and then enter a string, which will be placed into...
1,092
Not sure how to word the title but here's my scenario. We have a carriage that moves at high speed with an energy chain and the cable bends in a...
2,876
Hello plctalk, new guy here. I have an application that I'd like to present for your considered opinions so I can figure out what hardware I...
2,523
Hi, I frequently demonstrate automation product (that we make) to various customers. The system uses an AB7007 Anybus gateway that connects to...
5,321
