Sequence of Events Recorder
kumar satyam
Oct 2011
hyderabad
30
Hello everyone,
Has anyone worked on Sequence of Events Recorder in any system.
Can anyone brief it out tome or explain me what it is all about ?
Thanking you in advance
The sequence of events recorder will log data (usually I/O status with a real time clock) and store the data in the PLC/Computer. The data can then be reviewed at a latter time.
I like to think of this as a robust logging system because the data is stored in the PLC (Real Time) and it can then be retrieved when needed.
http://accautomation.ca/now-you-can-have-robust-data-logging-for-free-part-1/
Note: Some systems will go down to the millisecond time frame
Regards,
Garry
http://www.accautomation.ca
There are two basic ways to accomplish SOE. You can have SOE capable input modules that time stamp usually to 1 ms. This normally requires that you have the system connected to a GPS clock to normalize the time system wide.
Option 2 is that you have a standalone SOE system that is connected to the process inputs such as the following: http://www.mehtatech.com/
Usually the PLC option is less expensive if you already have a PLC in the scope.
Additionally, if you have electrical protection relays in your supply then these relays normally are connected to a time clock via IRIG b. The relays will internally time stamp the protection actions to a 1 ms accuracy. This is for modern numerical multi function relays.
I often make modifications on tristation, automatically it will generate new versions sequence of events SOE format and I have to copy and paste...
3,551
I am taking my first attempt at modifying a program on our little bottling machine. We need to automate a sequence to purge the tank on the...
4,820
There is a Demo system at the GEIP Support Web Site with everything needed** to play with or test a 32 point SOE with Millisecond time stamping...
3,622
hy, what does SOE (sequence of events) mean? does Siemens have digital input modules with this feature? which order number? thank you
6,773
I am new to programming. I am trying to figure out how to cycle my sequence of events for a number of times. I have 2 cylinders that I have been...
2,251
