Sercouse module sometimes going fault mode.
Saudi jamal
Jun 2015
oman
147
Hi guys,
Our Plc sercouse interface module sometimes going fault mode.it's OK indication led solid red.if this fault occurred the all servo drive going fault mode.it is happening since one year
We don't have idea why this fault occurred. Every time we down power cycling and restored
Restored normal operation.kindly note that there is two CPU and one CPU battery is now on fault mode.we are waiting for new battery replacement.
Kindly any idea would be great appreciate.
Jamal
Going online while the sercos is faulted and looking at the fault codes maybe a good start.
Thanks for your suggest. OK we will check online when there is sercose fault and we will post the details fault code.
Hello all, I have a 1756-EN2TR dual-port Ethernet IP Module attached to my 1756-L73 PLC. I currently have hazard symbols over both the top and...
73
We are facing intermittent issue with emergency stop and line stop. Line stop triggering with alarm of line stop push button activated at one...
222
Hello all. I am trying to communicate to an ASi gateway from my CpLX (L16ER). I am able to ping the gateway and it replies. I configured the...
134
Hello everyone, I've had this issue for the last 2 days where I try to assign the profisafe address to an IO block (6ES7 146-6FF00-0AB0) but when...
174
Hey guys, I just wanted to see if any of the bright minds on here had any opinions on these relay interface modules. Particularly, I would love to...
68
