serial programming cable for a ge 9030
Jeff23spl
Jan 2010
Canada
860
Do the Horner adapter RS 232 to snp adapter could work on that plc to go online with my laptop and Proficy ?
HE693SNP232A with a IC200CBL001A
I know it isn't the exact part number specified by GE for 90-30 but i have it and i do remember of used it for GE... but not sure if it was a 9030....
Regardless if i need to reverse pin 3-4, i have null modem converter too.
Search returned it may work but my local Ge don't want to confirm expecting to sell me the right one... but anyway they don't have it stock.
This was programmed by a non available colleague a long time ago and i will have to connect to it.
The project is also using ethernet module to communicate between each other 90-30 (x plc), can i use it to go online with Proficy or because it is used for send/receive data, the port would be busy and reserved ?
thanks
thanks Steve
I was able to reach my colleague in the meantime and he his confident it will work...i will see next week...
Dear all, I have these 2 problems. 1. siemens s7 200 programming cable 6ES7 901-3CB30-0XA0 (both ends serial ports). My laptop does not have a...
3,773
does anybody know the diagram of the REDLION KADET PROGRAMMING SERIAL CABLE diagram? we are using it first time. previously we are sing...
2,927
Hello I need to connect to a GE versamax Micro IC200UDD120 through RS-232 serial port 1 (RJ45) to program it. Does anyone knows the cable pinout...
7,219
Hello guys, I am new to WAGO PLCs and e!****pit. I am trying declare variables from a Modbus Slave Connected using serial to WAGO PFC200 and pass...
1,344
Dear All, I am a mechanical - 3D design engineer with almost no knowledge in plc programming (and limited knowledge in algorithms in general). I...
4,016
