Serial RS422 RK512/3964(R) to Profibus DP Slave(Baud Rate 1.5 Mbps) protocol convert
Apel
Aug 2007
Singapore
98
Hi everyone,
In my coming project we have to convert Serial RS422 RK512/3964(R)protocol to Profibus DP Slave(Baud Rate 1.5 Mbps).Any one who knows please advice me what kind of converter I should use?
MELSEC A RS422 (25pin) <> iQR C24 Serial RS232 (9pin) - Simple PLC Communication Communication from a MELSEC-A Series CPU (RS-422 – DB 25 Pin)...
1,053
Hi I wanted to control 4 Displays to switch input from a PLC with serial interface. The Display can be controlled via its serial port with ASCII...
1,283
Hi, I am trying to read weight from a Mettler Toledo weigh scale (ID1 Plus-A) to S7 400 seriec PLC, via CP441 serial card and RS422 interface...
1,824
Looking for recommendations for USB-C to serial adapters. Mainly used to connect to SLC and PLC5 processors.
178
Does anyone know of an AOI using the user ASCII protocol select on the L6x controllers that will talk Modbus RTU using RS-485? Thanks, Trevor...
149
