servo motor control
irondesk40
Jan 2008
nc
630
Is it possible to control the speed of a servo motor with a potentiometer? Give the servo the run signal, servo run to a certain postion then return home and keep running that profile until the servo run signal goes off.
Have applicaton to control a spray nozzle and boss wants a servo and a pot that he can turn.
In the servo projects i have done in the past i programmed the speed of the servo move in the software for the servo. It was a Yaskawa.
Which brands do folks recommend?
It could be done easily with A-B servos (Sercos or Ethernet). You set one axis as the virtual axis (master) and then the other axis as the slave. The vitual axis would have the pot as its speed reference. Less than 10 rungs of logic. I imagine most other servos will let you use a virtual axis as well.
Thanks, have done some machine with two servo axis - used festo, which i believe is actually a baldor with the festo name on it.
In that project I program in profile moves in the servo and then gave it inputs to move to certain positions.
Unfortunately all of the equipment we have is now in Asia,Europe and China so do not have direct access to experiment.
On this project all of the ac drives will be yaskawa and black max motors. We have used that combo on some pretty big projects the last couple of years and they worked great, plus the vendor we use is pretty good at getting you things when you need them quickly.
Hi; Normally if someone talks about SERVO, its refer to such a motor control system in which a motor, having permanent magnet on rooter, or a DC...
2,414
Hi all, Got an application where the customer is looking to use a servo motor, purely because of the very wide speed range required for different...
3,697
Hi guys, How do you control the servo motor using Omron driver and GX developer?
1,507
I am working on a project to control servo motor through servo drive and Omron CP1E N30 PLC . It was previously programmed by someone and now we...
1,150
Just the other day I saw a hydraulic forming press that didn't seem to have a pressure relief valve. It had a Servo motor connected to a pump that...
2,109
