Servos and Frequency converters
JIMCON
Sep 2005
SWEDEN
124
Hello all :)
I wonder is someone here knows where i can find info about how Serovs and Frequency converters work with plc`s
// Jim
try to find in a documentation about frequency converters. I read a docs for ET200S FC and micromaster, there is everything how it works. About servo I don't know, but there must be also something on siemens' www.
Ok Viele danke Martin.
Im just interessted in some basics how the PLC is controling them.
if there´s som kind of a special program block in the PLC.
I have never worked with Servos and FQ´s before.
I know how FQconvertes and servos work but not how to control them..
There is also how to control them. I am pretty sure, that there is a free software called Starter to commisioning FCs. Maybe this help you also:).
Grüß:)
Martin
I have 2 servos that is moving a gantry. I am planning to use one to follow the other using an MAPC command, but when I home, could I tie the home...
1,389
I have a unique project and will be commissioning it next week. It involves two servos that are both connected to the same belt in an H-type...
22
14,171
Hi All, We have encountered a problem with one of two servos that feed paper. The infeed roll was replaced and diameter of a new one is slightly...
2,188
Good Afternoon , I have a machine that has 7 - Kinetix 6000 servos on it . All the servos want to run high speed and cannot slow down...
2,161
Hey guys... I'm in the middle of a battle with the boss because when I try to tell him what I need he claims I don't know what I'm talking about...
3,013
