Set bit in word with Siemens SCL
Jan 2010
east
I got problem to set a bit in a word with symbolic name.
When I juse the DB adress its works( DB1.DBX4.3 := 1; )
Can somebody help me with the right expression?
This is my code but it will not work.
FUNCTION FC1: VOID
BEGIN
DB1.DBX4.3 := 1; //This is ok
"Test".X.UT[0] := 1; //This is ok when I set the word
"Test".X.UT[0].3 := 1; //This is not ok when I set the bit
END_FUNCTION
When you say it doesn't work you mean the code does not compile. Here's a possible work around:
Code:
FUNCTION FC1: VOID
VAR_TEMP
abData: ARRAY[0..15] OF BOOL;
wData AT abData: WORD;
END_VAR
BEGIN
DB1.DBX4.3 := 0; //This is ok
"Test".X.UT[0] := 0; //This is ok when I set the word
wData:="Test".X.UT[0];
abData[3]:=1;
"Test".X.UT[0] := wData;
END_FUNCTION
I have a project where a Micro820 was supplied by another vendor. I need to read status of the outputs of the M820 via Ethernet/IP from my...
2,146
I'm starting to learn some basic ladder logic. I'm on an AB Micrologix 1000 PLC. I'm wondering if the OTU instruction will work on an entire...
2,129
Hi Gents, I am new to Unity Pro and have to work in Funciton block. I have worked extensively in ladder with Ge-Fanuc. I am trying to find an...
4,148
Hi I am having a brain ache. What is the instruction to set a bit in a word, kinda like (set bit 2 of word D2) or (reset bit 2 of word D2). I...
3,212
What is the best way to set a bit over an ethernet/IP network on an Allen-Bradley ControlLogix Series PLC from a Windows PC. We have a program...
2,120
