Set up GE RX3i PLC to read Modbus TCP
wlr3m4
Oct 2017
Saint Louis
28
Is this possible? I want to read values from a power meter directly into my PLC. Is there any kind of documentation on how to set this up?
My CPU is a IC695CPE305.
I'd give it a miss. The implementation of Modbus/TCP in the Rx3/7i is horrible. You are much better off in my opinion getting a Modbus/TCP to Modbus/RTU converter/gateway and connecting it to a CMM module in your PLC rack.
it is just a little complicated, plenty of info on setup though.
I would get through it, once you are done you will have minor problems setting it up in the future.
I had problems with about 4 settings, after I got that resolved everything went great.
It is a lot easier if you only want to read (not write to device)....you don't have to close the connection, just set a timer for how often you want to read required integers.
This is important if you have more than 1 device you want to read from, just sequence the read commands so you do not try to read from more than one device at the same time.
Hello. I ask you to help this problem . I am currently using 02 stations located in all PACSystems RX3i . I experience this phenomenon is the 02...
4,318
In a Rx3i what would be the most efficient way to count the number of bits set in a word variable? The naive approach is to simply shift the bits...
1,174
I have an integer coming from an IO Link device into my PLC. The first 2 bits of the integer are digital status bits of 2 alarms in the device...
1,520
Using GE RX3i PLC with Machine Edition SW... I have a decimal %R number (value is "1150") that I want to write to a set of 16 %I bits to set 1 and...
18
4,793
Hi, i am using DVP-14SS2 PLC, after program written to plc, when power is reset, plc doesn't run. always need to connect to pc for the run mode.
33
