Setting a Mitsubishi FX3S real time clock in ladder logic.
HersheysMM
Feb 2017
IL
28
Hi everyone,
I am a greenhorn in programming. Can anyone help me with a GX Works ladder logic example of programming a real time clock. I want to be able to set different times within my code that run off the built in clock. I am using a Mitsubishi FX3S plc. I got the programming manual from Mitsubishi but the examples are only for Structured instead of ladder logic.
Thanks for your help.
http://dl.mitsubishielectric.com/dl/fa/document/manual/plc_fx/jy997d16601/jy997d16601q.pdf
37.2.7 Real time clock [M8015 to M8019 and D8013 to D8019]
M8015 Clock stop and preset
When M8015 turns ON, the real time clock is stopped.
At the edge from ON to OFF, the time from D8013 to D8019 is written to the PLC and the clock is started again.
Turn on M8015
Move the data into the real time clock area D8013 to D8019.
Turn off M8015
Hope this helps you out.
Regards,
Thanks for the input, meantime I have been reading some other forums and some are saying the Mitsubishi RTC will not keep accurate time. Someone said in a year it will come off an hour. I wanted to use this for a break timer, so for that it will need to be accurate. I have decided it may be better to just use one of Intermatics timers. I was thinking since I had this extra FX3S setting here I would use it.
Hi hope all are ok. I have mitsubishi PLC Q03UDV CPU. I have control a drive through modbus inteligent module QJ71MT91 in GX Works2. Any experts...
619
On our system, on the HMI we've got a page of setpoints. These are the values at which alarms are set (e.g. a high temperature alarm or a low...
1,241
I've got 4 float switches in a water tank. At the bottom of the tank is a pump which pumps water out of the tank (to circulate it in our water...
19
3,260
please help me I don't know lock password for plc mitsubishi how is setting password for plc mitsubishi FX1n ?
4,686
Hi I am having trouble getting a Digital to analogue converter card (mitsubishi Q62DAN) set up on a Q00J plc. I have already set up a Q68ADI on...
1,888
