Setting multiple bits from one PV button?
JerryH
Mar 2009
Tellico Plains,TN
110
I've got a PV600 connected to three machines on DH+ and am collecting data from counters from each one to display. I would like to add a button to reset all counters in each machine. How can I tie one button to three different node addresses to set a bit in each one to trigger the counter reset logic.
I've tried adding an invisible button over a button hoping both would actuate upon pressing the one displayed (this works in other touch panels) but I get an 'Overlapping Control Objects Error'
Any ideas???
Jerry
That's a Panelview Standard. An easy way to tell is the black bezel versus the gray bezel. The Panelview Plus has a gray bezel.
I don't think there's an easy way to do what you want with the PV standard. The only way I can think of would be to put a message in one PLC that sends the reset signal to the other two when it received a signal from the Panelview.
Paul
Yep, I was going to do it with a message bit unless someone knew a way around it in the Panelview.
thanks,
Jerry
Which PLC/SLC do you have. Look up "Global Status Flags"
for a PLC5 and "Global Status Word" for a SLC. Much easier way for processors to communicate between DH+ ports.
I did say message bit but I would use a bit in a 'Global Status Word' as these are SLC504's.
Jerry
Hi guys, so I'm using BOOTP/DHCP tool in my virtual machine for setting up an IP addresses for basically everything. My only issue is always with...
386
How to setting multiple ethernet? In excel file have layout of all network , concept and problem. Thank you very much.:thumb::thumb:
1,112
Hi Guys, I have got a problem regarding the setting of more than one limit for one input field. I have got four motors for extrusion & One for...
1,678
Good morning fellow sea captains and wizards, I am being asked to do the above and obtain 4 values from each slave, I know about the MRX and MWX...
32
987
SELECTED NEW FILE SELECTED PROCESSOR TYPE SELECTED I/O CONFIGURATIONS IM UNABLE TO CONFIGURE MY I/O’S. I HAVE A PAPER COPY OF A PROGRAM AND I...
103
