Setting Time and Date on Mitsi Q-series
will k
Apr 2007
Devon
Hey, hows it going? I was wondering if anyone can help me with setting the time and date on a q-series plc. I used the time settings window in GX Developer to set the time but for some reason the date was ahead by one day. So now I would like to correct it but it doesnt seem to update anymore. Do I have to format the memory before setting the date again and if so will i lose all my parameters. Thanks in advance for any advice,
Will
Will
you can use instruction [DATEWR] for update Date and Time of PLC
Yes, I did try that before using the time setting in GX Developer but was unsuccessful. I used the date write instruction with the starting register at D60 and I thought I stored the correct numbers in D61, D62 etc but the date and time didnt change. I'll give that another go and see...maybe I messed up the BCD coding or something. Thanks for the reply, I'll let you know how I get on.
Will
Hi Everyone, PLC: 1769-L30 V32 HMI: CR3000 Crimson 3.1 Current Version Years ago someone on this Forum gave me this program that will set the...
1,754
Below is how I set my PID LoopUpdate time, feel free to make suggestion or comments. The PID loop is used to regulate water back pressure. Since...
1,253
Redlion Graphite G07 Crimson 3.0 Build 624.005 How can you set the time and date from the HMI in a user friendly format? I know theres the...
23
14,166
Greetings In our plant we use a ControlLogix5563 as our main data handling PLC. Recently I noticed that the controller date/time setting differs...
4,187
Hello, Does anybody know how I can save the changed date of a Siemens TP170-b so that when I put the power on again its is still the date and...
4,011
