Setting up a Decreasing Timer for a Security System
bryan_finley
Dec 2012
arkansas
I am having trouble setting up a timer on Rslogix 5000.
I've gotten the hours by dividing my accum time by 36000000 but am having trouble getting the right minutes and Seconds. I need to figure out how to have my minutes go from 60-0 and same with the seconds. They go to 99. Any advice would be greatly appreciated!
Welcome to the Forum!
Have a look at the MOD Instruction, it should do what you need.
You can do it with Math of course, but this should save you a few steps. You can find the MOD Instruction in the Instruction Reference here;
http://literature.rockwellautomation.com/idc/groups/literature/documents/rm/1756-rm003_-en-p.pdf
You can also look in the RSLogix5000 Instruction Help.
Stu....
sthompson,
I set up the Mod Instruction. To get hours I make source B 36000000, minutes 600000, and seconds 1000000? And Source A Accum. for my security timer?
Can you give a better explanation of the you are trying to do? There may be a better approach depending on what you are really trying to accomplish.
Perhaps you could share your solution with the Forum. So someone in the future can benefit.
Stu....
Good morning fellow sea captains and wizards, I am being asked to do the above and obtain 4 values from each slave, I know about the MRX and MWX...
32
914
SELECTED NEW FILE SELECTED PROCESSOR TYPE SELECTED I/O CONFIGURATIONS IM UNABLE TO CONFIGURE MY I/O’S. I HAVE A PAPER COPY OF A PROGRAM AND I...
93
Does Rockwell still offer reset codes for old school Master Disk floppy's? In a bind and need to reset the activation disk soon and to be pointed...
254
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
94
Hello. I am trying to use a Prosoft AN-X4 to improve the communications for a new panelview plus 7. This is going from a SLC-500 through DH+ to a...
304
