Setting up a Multi-state Indicator with a CP2E and NB HMI
jaytacha
Aug 2023
Victoria
Hello all,
I'm coding on a CP2E-N with CX-programmer and trying to get my head around some of the clunkier parts of it, since I'm more familiar with Rockwell gear and Studio5000
I'm trying to set up a multi-state indicator on my HMI (NB model, I have NB designer and the two devices are talking fine) but I'm unable to work out how to set an integer of some description to have states 0, 1 and 2 to trigger a 3-state indicator correctly.
In Rockwell gear, the MOV function is smart and straightforward, but I feel like I'm missing proper syntax here in CX-programmer.
I've been playing with this rung to try and work it out, but haven't been making much progress. What am I missing?
When you say have not made much progress ? what is happening ? looking at your code you are putting a value of 2 into D0 is it doing that ?
Is the multistate indicator showing the status of the Value what ever that is ?
Not much to go on here, I assume the multistate indicator is something like
0 = "Some Text" or indication
1 = "some other Text" or indication
2 = "System Running"
& so on
Perhaps explain what the actual problem is. As far as I can see you are moving a value into a word & that should display a different message or symbol on the screen is it working or not.
Good morning fellow sea captains and wizards, I am being asked to do the above and obtain 4 values from each slave, I know about the MRX and MWX...
32
841
SELECTED NEW FILE SELECTED PROCESSOR TYPE SELECTED I/O CONFIGURATIONS IM UNABLE TO CONFIGURE MY I/O’S. I HAVE A PAPER COPY OF A PROGRAM AND I...
81
Does Rockwell still offer reset codes for old school Master Disk floppy's? In a bind and need to reset the activation disk soon and to be pointed...
230
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
87
Hello. I am trying to use a Prosoft AN-X4 to improve the communications for a new panelview plus 7. This is going from a SLC-500 through DH+ to a...
291
