I have to commision a servosystem where one of the axes has a modulus : it is a chain that keeps on turning in the same direction, comes back to zero each turn at the same point.
Because even afther numerous rotations my position has to be repeatable, I should need to know the exact ratio of motor revolutions to revolutions of the chain. If it concerned a small chain, I could count the teeth of the chainwheel connected to the drive and count the segments of the chain.
But because the chain is really long, this is no solution.
I was thinking of rotating the chain for multiple turns and look how many turns the motor made, and then guess for the
ratio motor/chain.
This must be a situation many of you encountered.
How do you find the exact ration of motor revolutions to 'chain' revolutions?
ratio motor/chain.
