Sorry your email bounced back. Can you give me an alternative email.
Hi Ranjith.
I sent my alternative email by private message, ok?
Thanks.
Done. you need to be careful when you wire your SBus.
Movidrive ----> Movitrac
1 Gnd ----> 3 Gnd
2 SC11 ----> 1 SC11
3 SC12 ----> 2 SC12
Hi.I have managed to get the Movidrive to control/monitor a Movitrac via SBus PD.
There is no IPOS program in the Movitrac this time. Unfortunately i cannot upload the files here but publish a screen shot of the Movidrive IPOS code.
I have this F42: Lag Error coming on Sew Movidrive MDX61B. The drive is on the crater...I have tried all remedies from the manual books but the error keeps coming. Anyone with an idea on how to resolve this error?You can use SBus. You need to give each drive a SBus address.
EX: Master-1, Slave A- 2 and Slave B-3 Parameter group 8.
You need FSC11B cards on Movitrac B drives.
Then loop SBus Terminals Between 3 drives. Turn the resistor on two outside drives.
Then you can read or write between the drives using Movilink or Scomm commands.
I have done this many times.
Let me know what you are trying to do with these drives.
Then I can help you further.
