SHRB block problem
michlam
May 2010
Planet Earth
Hello fellas
Im having trouble downloading this program to s7-200. (Se attachment)
No problem in program but just before it ends the download it shows up with a compiling error of the first SHRB block???
Any suggestions?
Long shot, but the example in the manual shows +4, have you tried entering +127
Edit - manual also states max length of shift register is 64 bits - that's your problem.
I want to use a shift register in S7 similiar to the Allen-Bradley BSL/BSR shift instructions. I found the FC92 bit shift register under standard...
17
10,883
I am using a SHRB for registers between 4082 to 4084. (see pic SHRB) I am using an interface to sometimes directly set values. So in the PLC...
1,342
I am using the SHRB instruction to shift bits with TISOFT. I was wondering if it is possible to set bits (by an interface) that are used by this...
2,725
1,726
Hi All, I'm just trying to understand the reason behind something I recently experienced. Background: The system contains 4 CompactLogix...
69
