You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser.
Sicam pass experet in need
I will really appreciate if I can get help here
Please note that I am new in SICAM PAS.
I have the following System, please see attached image.
1- HMI 1, HMI 2, SICAM Unit 1, & SICAM Unit 2 are connected together and I can ping them [FONT="][/FONT]
Easily "so in NW issue things are fine"
2- HMI 1 is a duplicated project from HMI 2
3- HMI 2 RT is working fine and establishing connection with SICAM PAS Unit 1 & 2. No problem at all
4- HMI 1 is not establishing any connection with both SICAM PAS Unit and Redundancy function also is not working.
I am really stuck here and am trying to find out the reason but "no idea" note that your kind support is appreciated
Why HMI 1 is not communicating with Server?
I have just installed SICAM SCC and SICAM PAS 8 and licensed both using EKB.
When I want to open SICAM PAS UI Configuration it doesn't start...
hello..I need SICAM 230 toolbox II (consider 2) editors manual..if anyone have it please send it..
thank you..:)
Hi all,
Now I am working with Sicam P50 multi function meters. It have 2 sets of Analogue outputs. I want to know how we can check its working or...
we have a SICAM PAS full server connected to a group of bay devices via a 2 switches "rugged com". for example C03A device is connected via...
Hi to all...
Being new to SICAM WINCC can any one guide me on how to start working with this software.I am using SICAM CONTROLLER, whose data is...
