Siemens 3964R
nizar_lakhani
Jul 2007
Pune
Can anyone give the details of 3964R protocol.? Does it require any special module to be attached to PLC for using this protocol? Please give all the details.
Actually its not a PLC. Its a HMI Beijer E1032. It supports this protocol and i want to communicate the HMI with Atlas copco Powermacs controller which also supports 3694R Protocol.
I am trying to achieve communications between a Siemens S5-115U CPU944B and a Proface 2500 series HMI using the second port of the PLC CPU and...
5,635
Hello everyone, I've had this issue for the last 2 days where I try to assign the profisafe address to an IO block (6ES7 146-6FF00-0AB0) but when...
64
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
87
Hello to all, I'm just starting with using CodeSys. Immediately, I have noticed that Codesys doesn't use data blocks like for example S7 does...
162
111
