Siemens and Delphi
mrtweaver
May 2007
Bloomsburg
329
I am not fully familiar with the Siemens product line so I thought I would post a small question session here concerning the Siemens Product line.
In a machine that is currently in house here they have a Siemens PLC. It has a hard drive in it. Or so I have been told, I have not personally seen it. Also I have been told that this unit is programmed in Delphi.
So with that being said did Siemens make a PLC with a hard drive that was programmed in Delphi?
If so what did they call it? Step 5, Step 7 or what?
Is there someone on this site here who is versed in Delphi and is prefered to be in the state of PA?
I ask this because I am reported to have a dump of the program and would like someone who is knowlegable in the area to guide me thru it. If they can.
Thanks and have a great day.
Hello,
I do not know if that is the case but, I do know a bit about Delphi, if you are referring to the programming language.
>...a dump of the program...
Do you mean you have the source code of the program?
Regards,
Mark
http://www.peakhmi.com/
I think it´s Siemens M7 you are facing, It could be programed with C or C++. But as I recall they dont manufacture them any more.
Post the dump, I´m sure that we (members) can guide you thru it.
Regards
Edmund
Mark, good day, to answer your questions, Yes I am talking about the programming language Delphi and there are a lot of terms that get used, some same dump some say source code, but it is the source code, I do not have the source code on PC I only have it in printed format, it was all I could get at this time. But I could scan off some pages and email them to you and then you could definately tell me if its Delphi or not. That is if your interested.
Hello,
Regards,
Mark
Hello mrtweaver;
Scan the first page of code, at least and post it here (as a jpg) so more of uds can have a look, and give opinions.
As edda pointed out, Siemens had a M7 processor for the S7-300 and S7-400 PLCs, processors with a hard-disk that ran C/C++ code.
M7/S7 installation and operation manual:
http://support.automation.siemens.com/WW/view/en/1136201
M7 system software design:
http://support.automation.siemens.com/WW/view/en/1136533
M7 ProC/C++ Writing C programs:
http://support.automation.siemens.com/WW/view/en/1137408
However, all M7 programming used C/C++ (with a Borland C compiler package if I remember well). I don't see how a Delphi program could run on it.
There is also a programming language used in S7-300/400 PLCs known as SCL, that is loosely based on PASCAL. Maybe something to look at when we see your code.
http://support.automation.siemens.com/WW/view/en/5581793
Hope this helps,
Daniel Chartier
Here are the first 3 pages of what I have. Total content is probably like 50 pages or so. I have asked around here at work and some people say that it looks like the old Pascal or the middle ground between pascal and C. But are unsure. I of course was told that it was Delphi so I dont know but anyone that can help I would greatly appreciate it.
Well I´m no Delphi expert but It doesn’t look like any delphicode I´ve ever seen...
In fact it doesn’t even look like a high-level programming language.
If you have the machine in the house why keep us in the dark. What is the serial numer etc on the equipment?
Is it really a Siemens PLC? Or other Siemens Equipment?
Hello Simon;
I hope this applies in this context:
FUP is the German translation of FBD (function block diagram), a programming language that represents networks as logic gates (AND, OR, NOR....).
FW stands for firmware, in English and German.
Hope this helps,
Daniel Chartier
I have never had the pleasure of working with a "Thermistor" until now and have a question. The Thermistor is a 10KOhm 4-20mA 2-wire device and I...
73
Hello, I have a CPU 317-2DP Firmware Version V2.1.8. In TIA Portal only V2.6 is available, and there is no option to upgrade FW. Then I open it...
176
432
123
174
