Siemens cabling: CP5711 to MP377, 9-pin, D-sub
AutomationTechBrian
Jul 2013
St. Cloud, MN
669
Should be an easy question. I just can't seem to search the right words...
I just got a Siemens CP5711... one goes to the PC via USB cable. The other end has a 9 pin D-sub connector, and this will connect to a MP377 touch panel. I can't find anywhere that spells out exactly which cable accomplishes this. I found the pin-outs in the CP5711 manual, but I'd prefer not to make my own cable. Can someone tell me where to find this cable already made?
I know there's a third-party cable source that is mentioned on this forum. It's still not clear to me witch cable is correct.
http://www.plccable.com/siemens-plc/
I would assume that you need to buy standard Profibus cable. It's an RS485 network with shield/ground.
Hello, I have s7-300 I/O modules and I want to install cabling system for them. I have two options to go with which are: - Simatic Top Connect...
1,569
210
147
Hi need help why this “failure 5 emergency stop “ appears at every startup in the morning ? Have to shut off main switch at least 10 times on...
19
308
116
