Siemens Cannot Connect To PLC
JDCROCKETT724
Jun 2010
Michigan
249
I am trying to connect to my plc to go online with it, but I receive the following error. I can ping the PLC, but nothing from step 7. I have V5.5 + SP3. Anyone have any ideas? I have been connected before without a problem.
Hello,
Have you chose the right interface for communication on simatic manager ?
The image that you have attached looks like you're using a wrong interface.
Regards.
Make sure the IP address of your PC matches the IP address of the PLC.
Enter it manually in your TCPIP settings as 192.168.1.10 for example.
Disable the automatic IP address.
Open your set PG/PC Interface and make sure you have the correct adapter selected and that it says <Active> after it. You could also try switching your WiFi off to avoid any conflict.
Genius! I was playing with the Simulator and it automatically changed the interface to the to that. I guess you have to manually change it back. Thanks everyone.
Hello,
I think that happens when you close PLCSIM program yourself. When you use the cloud-button in Simatic Manager to close it, it should revert back to the old settings
Hi , I am working on Siemens CPU 315-2DP(6es7315-2af03-0ab0) while working online i try to modify bool value memory address M33.3,M34.0 but it is...
2,329
Hi everyone.. Can anybody help me, My Simatic Step7 cannot tracing address using right click on I/O address using "Go To Location". If i do it the...
6,456
Hi, people. We have several CPU945 ( Siemens S5), combined with CP1430 they are connected via H1 Bus. I'm able to get connected to all of the...
2,965
225
153
