Siemens capacity fo Siwarex U
raguilas
Dec 2015
Sinaloa
48
Hi everyone, hope you can help me with this
I have a S7-1200 and 3 ET200M, I want to connect 2 Siwarex U(weighing module) to each ET200M and another 2 for the S7-1200, do anybody knows if that's possible?
There's a diagram in the following link
http://imgur.com/a/aNM0o
thanks in advance
Thank you for your answer, it was really helpful
is it possible to have the connections showed in the diagram if I use
the S7-1200 and WP231?
Best regards
No, You can't insert WP231 in ET200M, they have to be connected directly til a S7-1200 PLC ( you can have WP231 as Stand-alone, but then you will not have access to all parameters )
If you instead of your ET200M place a S7-1200 with the weighing modules, you can have a Master PLC with I-devices, then you will have access to all paramerters in your WP231
Hi, Is there a "rule of thumb" for Siemens logging capacity? By this I mean, if you are logging: 1 x data tag Floating point format Once per...
1,842
210
147
Hi need help why this “failure 5 emergency stop “ appears at every startup in the morning ? Have to shut off main switch at least 10 times on...
19
308
116
