Siemens CB155
MartinVerkerk
Nov 2005
Zwijndrecht
Hi guys,
If I use PPO3 in the profibus master and I send the start word on PZD1 (447F Hex) with setpoint (2000 Hex) the drive won't start!
I've changed the correct parameters in the drive for profibus communication...
Is there anybody who can help?
Wrong- a CB155 is for the old Combimasters.
Make sure P927 and P928 are set correctly. I typically put both to a 1.
Hello Martin;
A silly question: are you sending Hex 447F only, or a sequence of 447E and 447F?
Siemens drives need to see a rising edge on bit one of the control word to start up.
Hope this helps,
Daniel Chartier
HI everyone, i am new to Siemens plc programming and i am in need of some help. yesterday we had an S7-1200 CPU 1214C fail to turn on an output to...
164
Hi PLC people, think about this scenario: The PLC is somehow connected to the same network with the facilities` network. Then someone connects to...
84
Hello everyone, I've had this issue for the last 2 days where I try to assign the profisafe address to an IO block (6ES7 146-6FF00-0AB0) but when...
152
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
185
Hello to all, I'm just starting with using CodeSys. Immediately, I have noticed that Codesys doesn't use data blocks like for example S7 does...
182
