Siemens cfc blocks for masterdrive
Kataeb
Jan 2007
www.livelovelebanon.com
636
Dear Sirs,
We are trying to use Siemens CFC Blocks to parameterize and monitor a simovert masterdrive motion control (check the attached file).
But, we did not succeed in doing the following:
Download of the configured parameters from the cfc blocks to the drive
Online monitor and change of parameters (in the drive eeprom, like we do in drivemonitor)
If you completed the download- then DriveES Graphic is like Drive Monitor
meaning you can only monitor r (read) values
yesterday, i tried the following without success. can anyone help?
* in cfc blocks, I made parameter P554.1=601 and compiled (convert to a parameter set), but when I open the parameter set offline the parameter remained P554.1=0, why? Then I downloaded the parameter set to the drive and inside the drive the parameter also is equal to 0.
* online is not possible in cfc blocks: test mode is always off (cannot put it on), and goggles are not enabled. The PG is connected to the drive with profibus network, should I change the online settings in cfc blocks? How?
Good Morning. I wanted to ask if anyone knows where you can find and download examples of programs made in CSC, in essence I have to do a program...
1,817
Can any one...tell me how to install CFC and SFC packages in step7 5.5...???? When ever I open my siemens s7 project....a pop up windows tells CFC...
17,879
Hey guys, Good day! I would like to seek for help regarding a CFC function block of siemens. I am currently working on a project wherein I am...
4,016
Does anyone know how to make CFC editor/compiler to create same instance DB number for modified CFC chart objects? Sometimes, after change...
5,143
184
