Siemens - Citect
alekbeck
Mar 2009
Tønsberg
40
Hi everyone.
I am currently trying make a HMI program, where i want to view the remaning time of my timer. I manage to view the time in seconds * 10 (30s = 300) but is there eny way to convert this value to minuttes and seconds ? If not, is there a way to devide the number by 10 in citect ?
You define the converion in the variable tag list. Fill in the values for the plc values and the engineering values and citect will scale it for you.
Thank for you`re help.
I found out how to convert seconds in to 00:00 (MIN:SEC) but for this to work i need a block that ignores the decimals.
Example: 1,22 = 1 . Does siemens have a block that does this operation ? If not, is there a other way to do this ?
I have a simatic S7-200 smart PLC with SR20 CPU and ethernet port. I would like to interface it with my Vijeo citect 7.4. it would be really...
1,178
I need to know the steps to communicate Citect 2016 with Siemens S7 1500 using S7TCP driver. Thanks
27
17,895
hi how can i Communication between Siemens S7-300 and Vijeo Citect 7.2 with Ethernet tcp/ip ? please help me!🤞🏻🤞🏻
1,806
Hi, I have a plant with 400 CPU and a HMI system from Scada (7.20). I want to let the 400 cpu sync against Citect. Citect already time sync...
1,815
I'm wondering if anyone has any insight into Siemens communications and may be able to help me with a communications problem I'm having? I have a...
4,195
