Siemens COM Profibus 5.1 and USB Prommer
Hoosierdaddy
Dec 2007
Indiana
I have COM Profibus 5.1 w/Hotfixes 1,2, and 3 applied running on an XP platform. I am attempting to import a bus configuration via the USB Prommer from a 6ES5 374-1KH21 256kB memory card. Each time I try to import, I receive the following error in COM Profibus...
"MCRDCTRL
The appropriate memory card driver has not been activated or installed. Activate the driver within Control Panel under "configure memory card", or re-install COM Profibus."
I made sure that the memory card configuration is setup for USB autodetect. The PC is indicating recognition of the USB Prommer via a green arrow icon in the system tray. I have uninstalled/re-installed COM Profibus 5.1, and re-applied all hotfixes. Further, I have un-installed/re-installed the USB Prommer software(version 2.0). None of this has resolved my issue. The USB Prommer works fine with Step 5 and Step 7 packages. Where to go from here?
Update - Resolved with Service Pack 2
Well, it look like I've stumbled across a fix. Apparently there is a Service Pack 2 for COM Profibus 5.1. After a lot of digging, I found it on the wonderful Siemens web-site. Installing it seems to have done the trick!:unsure:
Hello I want to set up a communication through GSM or LTE from a PowerFlex drive and other instruments (flowmeter, level meter, etc.) to PC 100...
890
Hi all, First a heads up, this is my first time working with Siemens product so please bare with me. We are testing the Siemens Scalance W700...
3,238
Dear All, I have a question about the modbus communication with CM PtP. I'm using a power meter to measure current/ voltage/ power, and the...
2,236
Hello, I try to do the communication between a Siemens PLC and a B&R PLC through TCP/IP connection. I've no experience in this field, and I'm...
6,825
Hello, I have to program an OP-20 with COM TEXT, some body knows, where I can buy this software package?:hmmm:
1,605
