Siemens communication simulation (get/put)
dbozic
Oct 2013
Zagreb
74
Hello,
Does anyone have experience in simulating communication between two PLCSIM with GET/PUT commands?
I have TIA Portal V13 and have tried to simulate data exchange between two PLCSIM. I have error(status #1 - connection not established).
Everything is configured OK.
I have tried to simulate also in STEP7 V5.5 (Simatic Manager) with everything configured as in TIA, just to check.
Result is, with SFB blocks GET/PUT everything works as expected, and with FB blocks GET/PUT I have the same problem as in TIA?
Somewhere I have read that when you simulate communication with PLCSIM you must use SFB blocks, and with PLCS you use FB.
Does TIA Portal have SFB blocks GET/PUT? I cannot find it.
Thanks for your help!
Hi All, Can anybody help me in Simulating Profibus and modbus communication for Siemens system. I have to check only with my PC no hardware...
1,287
116
Hello Guys, I want to establish profinet communication between siemens plc and my system using python programming. Which python lib can i use to...
380
Hi Guys, I am trying to establish communication over profinet between Siemens S7-1200 PLC as IO device and codesys plc as IO controller. But I am...
43
2,880
Which signals do I have to use to get data from camera. For example camera detects a defect and sends signal to controller. Power cable: CCB-PWRIO-05
219
