Siemens Cp 343-1 problem with CPU315-2DP
May 2015
ALEXANDRIA
Dear Sirs,
I had a problem with CP 343-1 with CPU315-2DP.I had newly add the CP343-1 Ethernet module to the hardware to allow me to access this the CPU through Ethernet network like the other CPUs.But unfortunately sometimes when i try to go online i can access only the CP 343-1 & cannot access the CPU (like the attached photo 1.png) and in this case if i restarted the CPU i can access the CP 343-1 & CPU which is not possible all the time.This problem repeats again.So your kind support is really appreciated.
Thanks.
Thank you for your reply ...what did you mean by pu or cp runs out of connection resources?... but how could i invesigate this.Sorry I am a beginner in this field.
Dear Mr Jesper
Kindly find the attached photo...I Switched to MPI from set PC-PG Interface to allow me to monitor , i did as you advised and i attached the photo ...Is "S7 basic communication" Reserved but not Occupied the problem ?.
Another question how can i set the value "S7 Basic communication" to 4 for an example ? ... because i read on the internet the steps which are : Properties of your CPU >> Select the "Communication" tab >> set ""S7 Basic communication" to 4 .. but unfortunately i found the "Communication" tab in the online-mode ONLY and this value can't be modified in the online mode..any help plz.
Hi All, this is my first experience with the Siemens CP343-1 Profinet used as I/O Controller for manage ET200M remote I/O. Here my actual...
2,881
I have been facing problem in establishing communication between two PLCs. I am using Siemens S7-300 PLC and I am using CP343 Lean SIMATIC. NET...
6,054
I have just spend over a week trying to get a CP 343-1 lean working with a 317-2DP CPU. I have five other cards in the rack and I positioned the...
7,563
Hi everyone, I want to upload the program from my CPU317TF-2 DP to my PC via connecting to CP 343-1 Advanced since it has LAN ports and the CPU...
169
Hi, I have a customer with a S7300 from around 2013 which they link to approx 25 inverters, 3 DP to DP converters and 5 IM153 remote I/O units...
320
