Siemens CP: Iso connections with CP, but no S7 connections then ?
userxyz
May 2002
any
2,768
I'm trying to make 3 iso connections and one S7 connection with a CP. But, my 3 iso connections okay results in no s7 connection. If I delete those 3 iso connections, then my S7 connections establishes ?
Does this mean you cannot combine iso connections and standard s7 connection in a netpro config ?
Thanks in advance,
Kind regards,
Gerry
Hey Combo,
Not very well versed in this, but have you allowed for S7 connections in your CPU?
C
DEAR SIR, I WOULD LIKE TO KNOW THE DIFFERENCE BETWEEN ETHERNET TCP/IP AND ETHERNET ISO (SIEMENS USES THIS PROTOCOL BETWEEN CPU 414H/417H TO WIN...
11,937
Hello everyone, I've had this issue for the last 2 days where I try to assign the profisafe address to an IO block (6ES7 146-6FF00-0AB0) but when...
114
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
156
Hello to all, I'm just starting with using CodeSys. Immediately, I have noticed that Codesys doesn't use data blocks like for example S7 does...
169
113
