Siemens CP1241-7 GPRS - TIA PORTAL
plutonium
Jul 2015
Mars
36
Hi forum!
As this is the first time I'm using this kind of data transmision I'm completely lost in GPRS and Siemens and programing... I have a task of programming mentioned module to send some data on other side where Scada should show received data. I dont have any information what is on the other side and what is configured from other side.
I want to make as much as I can on my side of PLC, so please help me with any info as I dont even know where to start.
As I understood, I need SIM card inserted in module. And thats all I know.
Should I call some funtions in OB1? How do I chose which data will be sent on other side? A lot of other questions 🔨:unsure:
CPU 1214C DC/DC/DC - 6ES7 214-1AG40-0XB0
CP 1242-7 - 6GK7 242-7KX31-0XE0
91
322
168
Hi need help why this “failure 5 emergency stop “ appears at every startup in the morning ? Have to shut off main switch at least 10 times on...
19
319
132
