Siemens CPU3152PN/DP connection to Simatic PC station
kolii11
May 2011
London
I having a problem to connect my CPU 315 2PN/DP to a Siemens EX panel PC. The problem is i used to use the ethernet port to connect to a SimaticNET (Cp 343 lean) card , but now i have to remove the ethernet link and found an alternative connection between the CPU and the Siemens Panel PC. The problem the Panel PC has only one ethernet, and 2 coms port supporting rs 422,485 and 232. Please help me to find the best solution.
Ish
The problem is The panel pc has only one ethernet port, and i had to use it to communicate to a server , therefore i have no spare ethernet connection left. Can not use Switch as the network not allow me to connect PLC to it.( customer request )
Then add another ethernet card to the PC.
If that is not possible, then connect the PC to a Router so that the customer can separate the two networks.
Like this:
Customer LAN --- [Router port w DHCP / Router port w fix IP] --- PC and 315-2PN/DP.
You write that it is a Siemens Panel PC. Exactly which one ? Most Siemens Panel PCs have an onboard MPI/DP port.
If that is not the case, then you can add a CP5711 USB to MPI/DP converter. The CP5711 can be integrated in a Siemens "PC Station". The regular USB PC Adapter cannot.
And that was my post # 10000 !
Lets see what happens.
Do I get a reward .... or do I crash PLCTALKs server ??
The Panel PC is a Simatic HMI EX Panel PC ET-456.
No MPI/DP just 2 serial ( 422,485,232 ) and 2 USB
Actually no ports just screw terminals.
So a USB MPI converter (CP5711) will do the trick?
I will try the Router again (ask Customer ), last time they refused it.
I was looking at my Step7 and found the CP5711 there but i never used it. Is it easy to integrate?
Ish.
I use Siemens rarely i use Rockwell, that is why i sound "Stupid"
The CP5711 is no problem to integrate into a "PC Station".
But since you use an EX rated panel PC, I dont know if the CP5711 or any other device that are EX rated. It may be impossible to achieve what you need. I would INSIST on the router solution.
I used a purged cabinet system therefore if the CP5711 has a lead of at least 20cm then i can move it to the purged side of the cabinet.
The device (CP 5711 has to be in the Purge side).
Alternatively i can use USB extension cable.
Thanks for your help anyway.
Ish
I'm using the Siemens PRONETA software to do some IO testing currently. I love the simplicity and fast testing capability. Does anyone know about...
64
Hi, First time user of S5 Siemens. Is there any solution on how to solve this kind of error. HMI OP7 $613 DB-error No. 11 (0: 15) Siemens PLC...
156
137
Hi all! Please inform me if i can make programing of the HMI SIEMENS IPC477D from TIA Portal software or not? I do not have WINCC software but...
98
I have never had the pleasure of working with a "Thermistor" until now and have a question. The Thermistor is a 10KOhm 4-20mA 2-wire device and I...
135
