benmccormick
Hi guys,
Hoping someone can help me get this working.
We are trying to add a CP343-1 Lean card to an existing CPU318-2 setup (Simply to connect remotely via Ethernet).
The current setup has 1 HMI using the built-in MPI port & 2 VFD's using the built-in Profibus-DP port.
Adding & using the new card is actually working fine, but it seems to have broken the Profibus? The 2 drives are now not appearing online & the CPU is in fault due to trying to send/receive messages to the nodes it cannot find.
Going through settings at both the drives & PLC, nothing seems to be lost.
The only thing I can see that might be something is that the new Lean card has configured itself with the same diagnostic addresses as the VFD's (1021 & 1022). But it won't let me change these to anything else...
Any help would be greatly appreciated!
A screenshot attached for some reference (note it appears the DP port on the CPU is greyed out, however double-clicking the DP port, it says it is OK & ready).
