Siemens DO4 configuration
jeramiah
Mar 2009
Texas
53
How are the Siemens ET200iSP DO4 modules configured? Part number 6ES7132-7GD00-0AB0
I am having a problem getting the DO4's to show outputs, I am using a Siemens 315-2DP PLC with a CP432-5 communicating via Profibus to a ET200iSP IM152-1
I am not able to find any info on these to show how they need to be set up (ie...addressing) Hardware config show each module uses 2 bytes.
57
310
163
Hi need help why this “failure 5 emergency stop “ appears at every startup in the morning ? Have to shut off main switch at least 10 times on...
19
313
126
