Siemens FM352 camcard an interrupts
Plc_User
Dec 2005
Belgium
317
If I have a FM352 camcard that triggers hardware interrupts on camtracks, and a new hardware interrupt from a camtrack is triggered while OB40 is still processing another camtrack, will the last hardware interrupt be lost or will it be processed afterwards?
Hey Guys, need help comparing Siemens FM 352 cam controller with S7-1500 input and output cards. - Do i look for the input/output speeds ?? -...
2,171
60
315
164
Hi need help why this “failure 5 emergency stop “ appears at every startup in the morning ? Have to shut off main switch at least 10 times on...
19
313
