Siemens HMI DP Communication with Drives
erdemsvri
Jul 2009
Germany
172
Hi
Is there a possibility to communicate a Control Technics Unidrive Sp and a MKS Servo Control Module FS150 with a Siemens HMI and control the drives directly form the HMI without a PLC?
Show the current, voltage, load of the driver and the positions from the servo module in the HMI (TP or MP) and control the driver and the positioner from the HMI?
Hi
I believe the easiest way will be to add a Profibus module to both drives and use Profibus to Read/Write to both drives.
I know Unidrive allows for the Profi option (Add-on module to the drive), not sure about the MKS.
Hi, I have Siemens HMI 6AV6643-0CD01-1AX1 with Ethernet port but connected with Siemens PLC S7 314C 2DP on MPI port. Let me know can i get PLC...
2,530
hello dear we have a problem with communicate with delta dop hmi and siemens s7-300 cpu . we use ISO ON TCP connection and AG-SEND and AG-RECV...
3,513
This Problem happened many times, is it only because the wrong type DB10Q0 should be DB1010 or any other possible cause? HMI log file ...
8,587
I have been working on communicating with Siemens KTP600 Basic PN HMI from my microprocessor. The main communication protocol that HMI uses with...
12,652
Hi guys, I need the communication cable between S7 300 Siemens PLC and Hitech HMI. Can anyone help me? Many Thanks.
3,807
