Siemens IM151-8 Prosoft PLX32-EIP-SIE
awnet
Jun 2007
Viareggio
44
Hi All,
I have 2 PLC on the plant one is a CPU Siemens IM151-8 the other is an AB CompactLogix. Do you know if is it possible to connect by a Prosoft PLX32-EIP-SIE by ETHERNET? đź“š
Thank you very much.
Bye
Hi All,
Bye
It looks like it, although I've never used the device. The M151-8 is part of the S7300 CPU family, which the device claims to support.
I don't know how it would interact, but on the Siemens side, it looks like it accesses the memory directly, like an HMI or an OPC server. It doesn't support Profinet, or appear as IO. This may mean that it only supports slower communications (100ms or more between updates).
How fast do you need the communications to respond?
Hi In one of our machine, there is Seimens PLC IM151-8 PN/Dp CPU. HMI is connected via Ethernet and other devices are connected via Profibus...
3,131
Hi guys, I have IM151-8 Siemens PLC, i want to connect it with Modbus and read/write on it using Modbus protocol. How can i do this? Do i need...
2,564
Hi all, i want to make a TCP connection to an "other station" in Simatic Manager to be able to send commands to an external device. I wanted to...
1,937
Happy Saturday! I've never used the HF module before and am attempting to do some PROFIsafe testing, and the Link LEDs don't light up on either...
2,902
Ok then guys, I have a IM151-8 controlling a small stand alone filling/packaging line. When it was delivered it was set with the default...
2,706
