Siemens ITC2200 displays
DLMUK
Jun 2013
Southampton
311
Has anyone ever used one of the Siemens Industrial Thin Clients before?
What I would like to do with it is:
S7-1200 PLC and 9" HMI at a local station
ITC2200 at a remote viewing point (about 150m away)
Am I correct in thinking that the ITC2200 can be configured to mirror the HMI screen?
Also, is 150m a suitable distance? I can install a switch if needs be.
Cheers,
It sounds like that setup should work. You will probably need the network switch you mentioned, because Ethernet cables are designed for a max length of about 100m.
You may also need a license for the HMI, to be able to view it remotely. If it is a Siemens HMI, then you will need the Sm@rtService license, or something like that. I haven't needed it in a while. If I recall, the HMI and Thin Client will always be on the same screen, and the HMI can only be operated at one location at a time, either the local HMI or the remote thin client. Being active on one locks the other out.
I have never had the pleasure of working with a "Thermistor" until now and have a question. The Thermistor is a 10KOhm 4-20mA 2-wire device and I...
57
Hello, I have a CPU 317-2DP Firmware Version V2.1.8. In TIA Portal only V2.6 is available, and there is no option to upgrade FW. Then I open it...
174
HI everyone, i am new to Siemens plc programming and i am in need of some help. yesterday we had an S7-1200 CPU 1214C fail to turn on an output to...
415
Hi PLC people, think about this scenario: The PLC is somehow connected to the same network with the facilities` network. Then someone connects to...
121
Hello everyone, I've had this issue for the last 2 days where I try to assign the profisafe address to an IO block (6ES7 146-6FF00-0AB0) but when...
171
