Siemens LA-824 Power Output Module
M Hedge
Dec 2005
Ontario
Hello All,
I have a customer with a number of these Siemens output modules. They are controlling a number of heaters and are blowing fuses, seemingly, at random. Has anyone used these? Know of possible issues that would affect their operation? Replacement options?
Thanks.
Part No. 6AT 1120-0BA00-0AB0 and 6AT 1120-0EA00-0AA0
I'm running into the same issues, did you find a resolution to this problem?
Hello everyone, I've had this issue for the last 2 days where I try to assign the profisafe address to an IO block (6ES7 146-6FF00-0AB0) but when...
125
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
167
Hello to all, I'm just starting with using CodeSys. Immediately, I have noticed that Codesys doesn't use data blocks like for example S7 does...
175
115
333
