Siemens Local_tsap_id
DLMUK
Jun 2013
Southampton
311
On a modbus block for an S7-314 I need to set the parameter local_tsap_id and have the following description in the manual...
This parameter defines the local port number.
local_tsap_id[1] high byte of the local port number in hexadecimal
local_tsap_id[1] low byte of the local port number in hexadecimal
local_tsap_id[3-16] B#16#00
I understand the port number needs to be 2000. What I don't know is what to put in the high byte, low by fields.
I have my low byte as D0 and high byte as 7 in hex. Does this make sense?
my logic is...
low byte = 1101 0000 = D0 in hex
high byte = 0000 0111 = 7 in hex
my logic is...
What you did sounds right to me, but byte order/endianness issues are sometimes more complicated than they seem like they should be.
To be honest, I find the best way is to guess (like you did) then try it and see if it works. If it doesn't, flip it and see if it works the other way.
Hi I have the attached code and am testing it using PLC SIM. The PLC goes to STOP mode with an "Error when allocating local data", requested...
3,966
I would like to ask a question regarding local variables in S7-200. If I define a Byte in the local variable table of a subroutine and let's say...
7,009
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
46
Hello to all, I'm just starting with using CodeSys. Immediately, I have noticed that Codesys doesn't use data blocks like for example S7 does...
134
105
