Siemens Masterdrives 1 master 2 slaves
pauly
May 2002
South Wales,U.k
244
This a repost in the hope someone can give a little help,
I would like to control 2 slave masterdrives driving unwind stands from an existing masterdrive via simolink. We intend to retrofit a simolink card to the existing drive which has devicenet connection also. My first thought is to send the output of the ramp function generator of the existing masterdrive over simolink to the slaves as a speed reference, a trim setpoint is required to introduce some draw into the web the trim setpoint I intended to transmit via devicenet to the slaves. I am a bit unsure how to introduce the trim function within the drives and indeed how to synchronise the drives via simolink. Any ideas or thoughts are very much appreciated.
Dear Sirs, My boss got me some old used 'somebody else's spare' MasterDrives to stow as spares for our machines. Some are tagged as 'will...
2,392
Dear Sirs, What I need is some insight into 'Forming' the capacitors (or re-forming) inside a Siemens Rectifier. The box turns 480 Vac into...
3,281
Hi, Anybody would know the reason why I cannot change some parameters on a Siemens CU2 V1.2 card using Drive Monitor (latest version)? Looks like...
5,269
241
155
