usedplcs
Hi All,
Today we had a drive die on us. There was no backup but we have a duplicate drive in service.
Can't upload via AOP or starter but Siemens are investigating this.
We have replaced the drive and used the Quick Start Guide for 440.
With advise from a drives company we have also added the other required parameters, inputs outputs etc.
The drive now pulls the contactor in and shows it as running.
Times out after a set time as no pulsed feedback due to no movement.
BUT the frequency is showing negative Hz?
I am no drives guru...
So the motor is getting voltage but assume -ve Hz
My question is why -Hz and is this the reason the motor doesn't turn.
Is this a parameter setting wrong or could this be something else?
No support now available going into the weekend, so any help or guidance is very much welcome. Many Thanks
Rob
Rob
